RS2 help with tying in tails
Post by LabRat » Thu Mar 23, 2006 12:20 pm
All,
I'm a semi-beginning fly tyer looking for some advice. I am tying up some RS2s, and am having trouble figuring out the best way to tie the tails on. I am using this as a guide:
http://home.att.net/%7Eferenc/Tie-rs22.htm
I am wondering if I am having trouble b/c I am not using a straight shank hook (I was only able to find Tiemco 206BL hooks, which are fine wire curved shank hooks). Kevin Hutchinson at Sportmans Finest said they would work fine, but I have a devil of a time trying to get the tails to stay on one side or the other.
Post by mickmcco » Thu Mar 23, 2006 3:20 pm
Mark:
The tails are by far the hardest part of that fly. Mostly it takes practice, but there are a few tricks others have suggested. One is to tie in a small ball of dubbing at the bend and use it to split the tails. Another is to wrap the tag end of the thread back to the bend and pull it forward between the tails to split them. Another is to use a figure 8 wrap to capture them. Experiment and decide which works best for you.
Post by Jimbo Roberts » Thu Mar 23, 2006 5:10 pm
Mick, you can tie flys for me anytime! Jimbo
bhigdon
Post by bhigdon » Fri Mar 24, 2006 7:20 am
I use the ball on the butt method that Mick mentions. I skip the dubbing for speed. I just add a couple more turns of tread to create the ball.
Post by LabRat » Sat Mar 25, 2006 6:17 pm
Mick, thanks for the help with the RS2 today. It was great to meet you.
AlanKulcak
Post by AlanKulcak » Fri Nov 17, 2006 2:21 am
make your first 2 wraps loose then pull them tight with the tail in the correct position. Use your thumb and index finger to pinch the line against the hookshank as you make the wraps and it will help you hold everything together as you make the loose wraps.
There is nothing like making that perfect cast to a tailing red and watching him devour your fly and take off like a freight train!!!!
Wait... Setting the hook and watching a bow take air, that might be better!!!!
bassackwards
Post by bassackwards » Mon Jan 22, 2007 9:19 am
Not only is the split tail a pain to tie in, but one of the fibbets usually breaks off. I've started using a small clump of wood duck (about 5 fibers). I think the mottled markings look more like a mayfly nymph tail.
Post by LabRat » Mon Jan 22, 2007 12:06 pm
That's a good idea. I'll try that next time.
Post by John M. White » Mon Jan 22, 2007 12:44 pm
I use two fibers from a partridge feather to make the split tails. It works easily for me, and they are a little mottled as well, which I think makes it a little more buggy.
Post by mickmcco » Mon Jan 22, 2007 2:32 pm
If all else fails, use the bristles from a fine paint brush. They're usually pretty rugged.
wiscoy
Post by wiscoy » Wed Jan 24, 2007 12:04 pm
The other thing I found difficult when tying these flies was the ability to see the tails against the back drop of the vise (black tail against black vise). I found that putting a small piece of white tape on top of the vise, at the rear of the fly, helps you to see the tail fibers. Doing this then makes them easier to split.
